April 24, 2023 at 8:19 am
raushan79
SubscriberDear Sir,
I have installed Ansys 2023R1 on the server CPU working with Ubuntu 20.04. Now, I want to know how to run Fluent on the same platform using the command line as the server has no GUI option.
Thank you
April 24, 2023 at 10:55 am
Forum ModeratorI'd start here https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_gs_starting.html  Set the model up locally with a GUI and then launch onto the cluster with a journal to issue the number of iterations etc.Â
- The topic ‘How to run Fluent on Linux Server without GUI’ is closed to new replies.
- affinity not set
1487
1318
1171
