3D Design
3D Design
How to run a Spacelcaim macro without opening the Spacecalim GUI?
    • sirusblack07
      So I have a simple script that will generate some part and save it. All I want to do is to be able to execute that micro without opening the Spaceclaim GUI as is the operation is executed from the command line.
      Is there a specific command to do that?
      Many thanks,
    • Keyur Kanade
      SCDM can be run in batch mode from windows command prompt and execute a script.
      In a Windows command prompt, go the the folder
      C:\Program Files\ANSYS Inc\v193\scdm\spaceclaim.exe /RunScript="E:\temp\sample.py" /Headless=True /Splash=False /Welcome=False /ExitAfterScript=True
      and the arguments are:
      /RunScript - specify full path of script file
      /Headless - hide/show SCDM GUI
      /Splash - hide/show splash screen appearing while launching SCDM
      /Welcome - hide/show welcome screen
      /ExitAfterScript - specifies if SCDM application should exit when script is finished
      To access other command line options of SpaceClaim, type spaceclaim.exe /? in command line.
      Please go through help manual for more details
      Regards Keyur
  • The topic ‘How to run a Spacelcaim macro without opening the Spacecalim GUI?’ is closed to new replies.
