December 9, 2024 at 9:13 am
franciskho.kho
SubscriberHi,
I have cut out a connector launch pad model from a board file.
Unfortunately, the model is not at right angle, it is quite hard for me to do optimization in such angle.
Is there any method to locate whole model across all layers at the same angle?
Currnet model as below:
I would like to realise the model in this angle below: (Only for top layer)
I would like to rotate whole model together to keep the model as original as it is.
Thanks!
December 13, 2024 at 9:26 am
Yang Zhao
Ansys EmployeeHi Franc,
For an Object without Angle property, we can select it to display a rotated icon (green box in the middle of the figure below), and then manually rotate the Angle.
1. Select the object you want to rotate.
2. Drag the circular part of the rotation handle in the direction you want to rotate the object.
[Key Point] The default Rotation Increment is 5 degrees, which can be modified from the Layout Settings -> Other. Change the increment to a smaller value if we want to get an accurate rotation.
Yang
3377
1052
1050
886
842
