how to retieve data a specific path to assess the local failue criteria in ASME
    • 1668898257
      hi, all,
      i am performing Static Mechanical analysis in WORKBENCH. i am try to retreve the so-called " linearized primary principal stresses" which is specified in ASME VIII-2 para. 5.3.2,  for specific path defined already. i'd like to retrieve the "memembrane+bending stress" of S1,S2 and S3 in all the nodes along the path, and make a summation to compare with the limit indicate in ASME,any methods to achieve such a goal?
      Thanks in advance.
      Jay
    • danielshaw
      You do not need the linearized results at all points along the path to satisfy ASME code criteria.  You just the surface results.  You should be able to RMB on the tabel and export the results.  If not, you can use the MAPDL *GET command in a command object to extract the values.
