October 2, 2018 at 10:41 pm
lampela
SubscriberHi everyone,
I am struggling with restoring default window location in Design Modeler. I'm using workbench 19.1 version. I clicked something and as you see on the picture design modeler looks weird. How to restore default wiew? As you see i can't do that from viev pop up menu like it was possible in previous version.
October 2, 2018 at 11:20 pm
Sandeep Medikonda
Ansys EmployeeHi,Â
 Please try resetting in WB and if nothing works reset the appdata and that should fix the problem. Please see this discussion for details.
Sandeep
Best Practices to post on the Student Community -
October 9, 2018 at 7:37 pm
Gary Stofan
Ansys EmployeeThe "Reset Layout" is not available when BladeEditor toolbar is active.Â
User can disable BladeEditor from DM > Tools > Addins if he does not want to use it.
October 11, 2018 at 11:58 am
April 11, 2020 at 4:24 pm
adk48ist
SubscriberThere is no Addins under tools on my workbenchÂ
there is only extensions
April 12, 2020 at 10:21 am
Aniket
Forum Moderatoradk48ist Please post a new query if you feel this solved query does not answer your question. Also, Gary has asked to use Tools in DM not in workbench.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
June 27, 2020 at 3:55 pm
sahil
SubscriberHello everyone,
I am getting a problem in restoring the default window location in the Design Modeler the same as lampela. I'm using workbench 2020 R1. Â
As @adk48ist suggests, but there is no Addins under tools on DM. Please anyone can help me to solve this issue.Â
March 31, 2021 at 8:44 pm
MahdiA
SubscriberGray_S thank you. it was helpfuln -
November 10, 2022 at 10:31 pm
Grant Jarrett
SubscriberOnce you go to tools, you have to click on options, than a window will open up that has Addins. However, I did this and disabled blade editor but I still cannot revert my windows to default.
January 31, 2023 at 9:51 pm
AlexSzatmary
SubscriberHere is how to do it step-by-step. In Design Modeler,
1. Click Tools>Options2. Click Addins.3. Set "BladeModeler Licensing" to "No".4. Close and re-open Design Modeler.5. Click View>Windows>Reset Layout
- The topic ‘How to restore View in Design Modeller’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
4067
1487
