October 12, 2023 at 8:56 am
October 12, 2023 at 3:25 pm
Govindan Nagappan
Ansys EmployeeCan you post an image of the model in Mechanical (Row $Â Model cell in ACP Pre system)
Do you have surface/solid/line bodies? What mesh method did you use?
October 12, 2023 at 5:07 pm
Ro.hi
SubscriberSorry sir. It is confidential, but the model is a solid and I had used mesh like a default I just had changed the size to 4mm
October 12, 2023 at 5:24 pm
Govindan Nagappan
Ansys EmployeeACP needs a shell mesh and not solid mesh. You can spcify the lay up in ACP and build the solid mesh in ACP. You can create a shell composite model or a solid composite model in ACP. But the input should be a shell mesh
October 12, 2023 at 5:32 pm
Ro.hi
SubscriberOk sir. Thank you so much
Viewing 4 reply threads
- The topic ‘How to resolve Input Validation failure in ACP (pre)?’ is closed to new replies.
1891
1419
 (11).jpeg)
