January 16, 2023 at 5:31 amSjoerd Huurdeman
Dear Support,
I received an 3D model of the client. When I open this model in Trutops design there are brown surfaces instead of grey. How can I repair brown surfaces in Spaceclaim / Trutopsdesign? As long as the surfaces are brown, I am not able to make a flat pattern!
January 16, 2023 at 7:46 amDevendra BadgujarForum Moderator
Hello Sjoerd Huurdeman
Please check the attached repaired model. The issue was with the corner 1 which was not getting assigned as junction. For Junction 2 it was straightforward to assign as the corner was fine.Â
For corner 1 issue, I had to split the body into two then used pull/move operations to create a proper corner to assign a junction. I was able to unfold to create a flat pattern.Â
Let me know if you have any questions on this.
Regards.
January 16, 2023 at 8:37 amSjoerd Huurdeman
Hi Devendra,
Thanks you for your answer. I have 2 adiitional questions:
- How did you manage to make the brown surface into grey?
- What is the meaning of a brown surface?
January 16, 2023 at 9:58 amSjoerd Huurdeman
Besides that I have the problem concerning not fully flat: (see picture)
January 20, 2023 at 1:19 amDevendra BadgujarForum Moderator
-How did you manage to make the brown surface into grey?
If you look at the corners where you need junctions to flatten/unfold the Sheetmetal is not proper and has some issues. I have attached a short video demonstrating the steps to repair this corner and to create a proper bend at that location.Â
It is just saying that it has not converted to Sheetmetal from Solid properly.Â
Please check the attached video for the same. Thank you!
Let me know if you need any further assistance.Â
Regards.
January 23, 2023 at 10:04 am
- The topic ‘How to repair brown surfaces in Spaceclaim / Trutopsdesign?’ is closed to new replies.
- Data Center Simulation
- Unable to attach geometry 2024 R2
- Getting Mesh Faces With Specified Normal Via SpaceClaim Scripting (V241)
- How to provide blade angles in bladegen.
- DXF file loaded incorrectly
- plugin error failed to import assembly from spaceclaim
- Crash by using Script Editor
- Overlapping contact face
- Thermoelectric Cooler Model
- Temperature’s Distribution not available in Refine Mode ?
1281
591
544
524
366
