December 3, 2023 at 8:15 pm
Nate K.
SubscriberHello Forum,
I am looking for help refining the mesh for a wind turbine. In particular, refining the outer domain mesh of 10mm cells to where it meets the inner domain mesh of 4mm cells. See pics. The second is the same area just zoomed in. I can apply edge refinement to the circle between the two domains but the refinement is applied to the interior of the circle. I have not been able to make it refine to the outside of the circle where it is needed. Is this possible?
[I am using Fluent Meshing through a Workbench project so am not using the standalone Fluent with Fluent Meshing where watertight geometry meshing is had (hope that makes sense, Ansys is a bit confusing with all its softwares and similar namings etc). I prefer to not use Fluent with Fluent Meshing, if possible, considering the learning curve and the short time remaining in my university class.]Â
-NateÂ
December 4, 2023 at 6:08 am
SRP
Ansys EmployeeHi,
Your question is not visible, can you please again post your question?
Thank you.
December 4, 2023 at 6:14 pm
Nate K.
Subscriber...I have updated the post. Thanks.
December 5, 2023 at 4:15 pm
Nate K.
SubscriberHello SRP,
By any chance, are you able to help?
-Nate
December 6, 2023 at 12:36 am
Nate K.
SubscriberIt has been a few days since posting. Can anyone at Ansys help?
Thanks, Nate
December 6, 2023 at 5:12 am
SRP
Ansys EmployeeHi,
Did you applied shared topology between the two surfaces? You can find more details on shared topology at user's guide: 3.8. Applying Share Topology (ansys.com)
I suggest you to create conformal mesh. A conformal mesh ensures that the nodes on both sides of the interface matches. With a non-conformal mesh, the nodes on one side of the interface does not match the nodes on the other side of the interface. The reason why conformal meshes is preferred over non-conformal meshes: with a conformal mesh there is no (or very little) interpolation at the interface which therefore reduces computational time and ensures higher accuracy of the solution.
Hope this helps you.
- The topic ‘How To Refine Mesh — Outer Area Edge Refinement’ is closed to new replies.
6680
1313
