August 3, 2020 at 3:13 am
prajput
How to quickly create surface bodies from multiple closed edge loops of an imported DXF file?
August 3, 2020 at 3:21 am
Karthik Remella
AdministratorSelect Fill tool and then select all the edges using box select. This will quickly create a single surface for all the edges. Though a single surface is created, it will have the imprints of all the edge loops present in the model. Now, if you select that single surface and then right click and select "Detach All", all the closed regions will separate out into separate surfaces. -
August 3, 2020 at 7:39 am
prajput
Fill command fails to create surfaces. Why?
August 3, 2020 at 10:06 am
Karthik Remella
AdministratorPlease observe the edge loop closely. It may not be closed. Please close the edge loop and then use Fill command. -
August 3, 2020 at 10:36 am
prajput
Can I use any different command to create surfaces from edge loops which are not closed?
August 3, 2020 at 10:41 am
Karthik Remella
AdministratorYes, you can create surfaces from edges with different commands in SpaceClaim. You can use Blend tool or you can use Pull command to create surfaces from edges. Please see help document for more details about Blend and Pull command.Â
Viewing 5 reply threads
- The topic ‘“How to quickly create surface bodies from multiple closed edge loops of an imported DXF file?’ is closed to new replies.
1461
1287
1135
