October 20, 2024 at 4:03 pm
asustark700
SubscriberHi there!Hope you are also doing well!Âi am trying to design and analyse a centrifugal impeller, according to my calculation...Âinlet blade angle is 30deg.backsweep angle is 60deg.ÂBut my question: How can i make blade with angles in bladegen only?i tried a lot but i am unable to do so
Thanking you.Âsending positive vibes!!!cheap person -
October 25, 2024 at 4:08 pm
rfblumen
Ansys EmployeeGiven an inlet blade angle and a backsweep angle for a centrifugal impeller, the easiest way to implement these into BladeGen is the following (i'm assuming you're starting from the beginning):
-Open BladeGen. Select File->New->BladeGen Model. Select "Radial Impeller". Adjust the meridional (z,r) coordinates to reflect your design (or do this later). Accept the initial angle/thickness values (this can be changed later)
-In quadrant 3 (i.e. Angle View), RMB inside the window and select "Beta Definition" from the pop-up menu. The default curve type is spline. It's easier to work with a Bezier curve definition, so RMB in the window again and select "Convert Points to"->"Bezier Control Points". Hit "OK" on the Point Count Dialag pop-up window.
-Note that the beta angle definition is based on the axial direction by default (this can be changed to the tangential direction by going to Model->Ang/Thk Beta Definition). Typically, the backsweep angle is based on the tangential direction, so an appropriate angle transformation will need to be madeÂ
-In the Angle View, double click on the first Beta angle point and enter the inlet angle. Double-click on the last Beta angle point and enter the angle representing the backsweep angle.Â
Note that this has adjusted the beta angles for the hub layer. The above steps will need to be repeated for all the active layers. The intermediate beta Bezier curve points will then need to be adjusted to provide a consistent theta distribution (or "blade wrap angle") for all layers.
March 7, 2026 at 2:34 pm
vuminhduc280903
SubscriberHello Rob Blumenthal,
I hope you are doing well.
Currently, I am trying to design straight blades with a blade angle of 45° relative to the axial direction. I attempted to follow the method you suggested. However, the blade I obtained has a rather strange trailing edge, which makes me wonder whether BladeGen might not be suitable for designing straight blades.
I also tried importing this blade into TurboGrid for meshing, but I noticed that the mesh quality is quite poor, which makes me suspect that the blade geometry may have been defined incorrectly.
I would greatly appreciate your help in guiding me on how to properly design this blade. The blade I am trying to create should have a constant wrap angle and a constant metal blade angle at every layer from hub to shroud.
Thank you very much for your assistance.
March 7, 2026 at 5:52 pm
rfblumen
SubscriberFrom your design goals:
- I am trying to design straight blades with a blade angle of 45° relative to the axial direction.
- The blade I am trying to create should have a constant wrap angle and a constant metal blade angle at every layer from hub to shroud.
I'm assuming you're wanting to create an axial blade such that the blade has a constant beta angle of 45 deg at all locations on the blade from hub to shroud. You can easily do that on BladeGen by controlling the Beta angle at just the hub and shroud layers. Specify Beta to be a straight line at both the hub and shroud laters and specify a constant value of Beta to be 45 degrees at the leading and trailing edge points. This will create a constant section blade (i.e. a "straight" blade).Â
Note that the blade wrap angle at the hub will be greater than the blade wrap angle at shroud. By definition, beta=atan(r*dtheta/dm). Assuming constant meridional distances at each span fraction, in order to keep beta constant at all span fractions (i.e. a larger radius), the overall blade wrap (i.e. theta at the trailing edge) at a given span fraction must decrease as span fraction increases.
March 9, 2026 at 5:09 am
vuminhduc280903
SubscriberHello rfblumen,
I followed your approach and was able to complete the design. However, the geometry near the trailing edge of the blade becomes slightly distorted and appears somewhat broken. In addition, the outlet region of the blade is excessively twisted, which makes meshing in TurboGrid difficult.
Could you please give me some advice on how to improve the meshing process in TurboGrid? My goal is to achieve an orthogonal angle (ortho angle) of around 50–60 degrees.
Thank you very much for your advice and assistance.
March 9, 2026 at 2:49 pm
rfblumen
SubscriberI used the Simple Axial template in BladeGen in Ang/Thk mode. There were no issues with the blade in BladeGen or the mesh in TurboGrid. I would follow that approach and then compare the resulting blade design with the original blade you're creating to understand the differences.
March 9, 2026 at 3:58 pm
vuminhduc280903
SubscriberThank you for your help. Can i have your contact to discuss more or i send you the picture that i design
March 9, 2026 at 4:17 pm
rfblumen
SubscriberPlease submit a support case through the Ansys Customer Portal and I can provide further assistance.
5979
1307
