January 9, 2022 at 3:16 pm
Baloch
SubscriberDear All,
I am using a python script to control longitudinal spring in transient analysis. How I can make it sure whether the script is working or not? Because when I run the problem and looking into solver output there is no information in the solver out put about the script.
January 10, 2022 at 7:49 amErik Kostson
Ansys EmployeeHi
I would try to run a simple test case (as shown below), where you use this script, and thus expect a certain behaviour.
So say the spring changes stiffness halfway through the analysis (say from 1 N/mm to 2 N/mm at time 9.5 sec.) then in the spring probe for the spring which is just attached to a block which is being pulled by a constant displacement (1 mm), we should see the force in the spring doubling from 1 N to 2 N, just as shown below so that is a simple example on how to see that the script (apdl to have time dependent stiffness) works.
Of course one can create many different type of tests so this is just a simple one for reference, and in order to explain how one can check if a script does what it is supposed to do.
All the best
Erik
January 12, 2022 at 1:51 pmBaloch
SubscriberDear
If possible can you share a snap of the apdl script you used?
January 12, 2022 at 2:57 pmErik Kostson
Ansys EmployeeHi
See this post where the snippet is shown - the only difference here is tha the *dim array kfreq should be a function of time not frequency,
so the array is ktime called say and defined as:
*DIM,ktime,table,5,1,,TIME
RMODIF,_sid,1,%ktime%
Of course you need to assign the appropriate values to ktime just as is done in that post for kfreq - of course you need your own time and stiffness values, this is just for reference.
For more info see the *DIM, and RMODIF commands.
All the best
Erik
Viewing 3 reply threads- The topic ‘How to properly trace a python script working in a transient analysis or not?’ is closed to new replies.
Innovation SpaceTrending discussions- LPBF Simulation of dissimilar materials in ANSYS mechanical (Thermal Transient)
- APDL, memory, solid
- Meaning of the error
- Contact stiffness too big
Top Contributors-
4167
1487
1363
1194
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
