July 16, 2024 at 12:45 am
asceduardo
SubscriberI am investigating the dynamical behaviour of a beam using Transient Structural analysis. In my study, I need to prescribe specific displacements for dozens of nodes simultaneously. Prescribing displacements node per node would require too much time and effort, and a named selections give the same displacements for all nodes at once. Instead, I would like to create something like this:
Node | Displacement
001: 0.00
002: 0.01
003: 0.03
010: 0.01
100: 0.02
(etc)Does anyone know how can I create a set of displacements like this? Thanks in advance.
July 16, 2024 at 2:29 pm
Ashish Khemka
Forum ModeratorHi,
You can use External Data module to import the data from an excel or other text file into Transient Structural Analysis.
Ashish Khemka
July 16, 2024 at 3:51 pm
dlooman
Ansys EmployeeIt might be possible if you have a value for each node in the named selection in a two column text file of node and values separated by a space or comma. DLIST can be used afterward to check if it worked. Mid-side nodes might interfere with this process.
*dim,d_vals,table,100,,,node     ! For 100 valuesÂ
*tread,d_vals(1),filename,txt     ! read node and displacement values from file
cmsel,s,named_selectionÂ
d,all,ux,%d_vals%Â
allselÂ
dlist
July 25, 2024 at 6:15 pm
asceduardo
SubscriberThank you. I have successfully imported external data from Excel (".csv") into my model following the instructions you gave me. However, for some reason Ansys will only accept static forces/displacements. To perform dynamical simulations, data must be dependent of time:
X-Coordinate | Displacement
0.00 | 0.000
0.01 | 0.001*sin(time)
0.02 | 0.003*sin(time)
(etc)Typing "sin(time)" works for displacements/forces defined inside Ansys, but it does not work for external data. Do you know how can I solve that?
July 25, 2024 at 7:28 pm
dlooman
Ansys EmployeeIf you want the displacements to be interpreted as sinusoidal do a harmonic analysis:
antype,harm
harf,value    ! frequency of sinusoid in hz
July 25, 2024 at 7:44 pm
asceduardo
SubscriberIs there any form of doing that in Transient Analysis? I think Harmonic Analysis does not fit my objetive because I would like to include any functions of time and not only sinusoidal ones.
July 25, 2024 at 7:52 pm
dlooman
Ansys EmployeeProbably not. How many cycles do you need to run? Â
- The topic ‘How to prescribe displacements for a set of multiple nodes simulteanouly?’ is closed to new replies.
5799
