July 23, 2021 at 4:11 pm
andrefff1
SubscriberHello,
I did a structural simulation of a cylindrical object and I would like to have a graph plotting the following:
The average directional deformation Y in a cross-section / The position Z in a given cross-section
I believe I would be able to do this easily in CFX with other parameters, but I have less familiarity with Ansys Structural.
Here is a picture of the geometry I am working with:
July 29, 2021 at 4:15 pmdlooman
Ansys EmployeeYou will need to create coordinate systems at each Z location and then Insert Construction Geometry (Surface) in the Model cell based on each coordinate system. The coordinate system Z axis should be aligned with global Z in the example above. Then a Directional Deformation (Y) can be scoped to each Surface and the details will display the average Y displacement.
July 29, 2021 at 10:06 pmhesamkeshavarzz
SubscriberHiIts so simpler than what said, the only thing you need to do, is to create a section plane, then in the resulted plane you could have your parameters, by choosing them.
https://www.youtube.com/watch?v=T4p8eAdx4DE
July 31, 2021 at 1:22 amandrefff1
SubscriberThank you all for the feedback I just exported all points with coordinates and manipulated those in a spreadsheet program. It is not ideal but it got the job done.
Viewing 3 reply threads- The topic ‘How to plot the average directional deformation along a centerline?’ is closed to new replies.
