June 1, 2024 at 3:11 pm
A Feiz
SubscriberHello all.
I am simulating a single pouch battery via ANSYS fluent. I want maximum temperature tobe plotted along with DOD. I cant figure out how to make this plot in fluent. I am using the NTGK model.Â
Please help me.
July 11, 2024 at 2:10 pm
Murari Iyengar
Ansys EmployeePlease look through the following steps to do this.Â
1.Ensure that your simulation has been set up to track the temperature and DOD. You can use Report Definitions for this. Kindly see 41.2. Monitoring and Reporting Solution Data (ansys.com)
2. After running the simulation, go to the post-processing section in Fluent.
3. Use the post-processing tools to create a custom field function if necessary, which represents the maximum temperature. See 42.5. Custom Field Functions (ansys.com)
4. Similarly, create a field function for DOD.
5. Plot the desired parameters using the Fluent post-processing graphics and plots options. See 40.11. Histogram and XY Plots (ansys.com)
- The topic ‘How to plot temperature vs DOD (depth of discharge) while using the MSMD model?’ is closed to new replies.
6189
