September 15, 2023 at 1:33 pm
phuonganhlovely.me
SubscriberHi guys!
I have simulation (magnetostatic type) a surface mounted PM spherical motor, i want to plot the magnetic flux density in different axis (x,y,z) and different plane (xy, xz, yz, xyz) to evaluation the magnetic flux density ? my method to plot the x,y,z axis is i draw 3 circel in 3 axis at the air gap and used fields calculator to plot the magnetic flux density. it is true method ? and i have no idea to do for the plane.Â
I am really appriciate with any idea or advice for tthe solution. Thank you so much.B_z is the circel z axisÂ
B_x is the circel x axisÂ
B_y is the circel y axisÂ
September 19, 2023 at 9:19 pm
DELI
Ansys EmployeeHi, you can plot Bx, By and Bz on the geometry by: Selecting desired geometry->Maxwell 2D/3D->Fields->Named Expression->Bx/By/Bz The geometry could be a point, a line, an object or a plane. -
September 20, 2023 at 5:07 pm
phuonganhlovely.me
SubscriberÂ
thank a lot for your replyÂ
the spherical rotor how can i draw the line or circle if i want to plot air gap magnetic flux density in the z axis or the plane also for the other axis, plane and special for the XYZ plane.Â
Thanks in advanceÂ
- The topic ‘How to plot air gap magnetic flux density in different axis and different plane’ is closed to new replies.
