how to perform multiplication on result data?
    • Fuad87
      Simulation model: A composite model with a cube reinforced with fibers. So the cube has 6 surfaces and few fibers are cut by the surface. So there are few fiber nodes on all 6 surfaces. Cube is modeled with solid elements but fibers are modeled as REINF264 elements. This is a multistep simulations.
    • Erik Kostson
      Hi
      THere are some capabilities within apdl to multiply say arrays or result variables.
      Check commands like plnsol, *dim, prod, quote, *voper,*get,.....
      (also chapter 3.10 in apdl manual, array parameters called)
      With this one can perform these operations. Perhaps there are also some examples on the internet on how to do that.
      Best of luck
      Erik
  • The topic ‘how to perform multiplication on result data?’ is closed to new replies.
