How to pass structural change data to fluent
    • h395523899
      I want to simulate the effect of model structure changes on the flow field.
      For example, the influence of the deformation of the pipeline on the flow field inside the pipeline.
      How can I transfer structural change data to the fluent?
    • raul.raghav
       You can use System Coupling to transfer the loads. Please refer to:
      https://www.youtube.com/watch?v=9aHWSZghFn8
    • h395523899
      Can the workbench perform the fluid-solid two-way coupling of mechanical apdl and fluent?
      Or do the fluid-solid two-way coupling directly in the mechanical apdl?
    • DrAmine
      System coupling is in the Workbench. You do not need any adpl snippets for coupling.
    • h395523899
      Although the workbench can perform fluid-solid two-way coupling, my partner is only familiar with the mechanical apdl.
      He built the model using mechanical apdl programming and performed force deformation analysis.
      Now I want to use fluent to analyze the effect of model deformation on the flow field.
      How should I operate to fluid-solid coupling the mechanical apdl to the fluent.
      Or can ansys multiphysics do it?
    • BiomedModeller
      Hi,nI was wondering if you could find the solution for what you asked. I also want to couple ADPL and Fluent as my partner has done the work in ADPLn
Viewing 5 reply threads
  • The topic ‘How to pass structural change data to fluent’ is closed to new replies.
