May 6, 2022 at 12:56 pm
shanmukhvaranasi
SubscriberI am unable to select simultaneously the faces on the fluid volume and the corresponding faces on the enclosed solid body to parametrize them. How to parametrize the corresponding features on both bodies with single parameter so that they change together.
May 6, 2022 at 6:11 pmpeteroznewman
SubscriberUse DesignModeler. Create the solid body using a parameter, then create the fluid volume using the same parameter.
Viewing 1 reply thread- The topic ‘How to parametrize enclosing body and corresponding fluid volume features with single parameter?’ is closed to new replies.
3727
1328
1163
1090
1014
