October 24, 2021 at 3:53 am
chenqingsen
SubscriberIn workbench, I want to output some self define times point for different step. But in the analysis setting , it can't define specific time point? So in workbench , is any way to define ? In ANSYS classic , the APDL command is outres
October 25, 2021 at 11:30 amAniket
Forum ModeratorDo you want to set up specific substeps? https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/wb_sim/ds_establish_analysis_settings.html
or do you want to change the output to write the specified solution item every nth (and the last) substep of each load step? If you have the APDL command simply insert a command snippet under the analysis settings, and write your commands there.
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v212/en/wb_sim/ds_commands_object_sol.html
-Aniket
October 25, 2021 at 2:11 pmchenqingsen
SubscriberI just want to write the specified solutionresult to the result file.
For example, I set 3 steps and the times are 1000s , 2000s , 3000s . But I want to write the 100s, 200s ,500s,1500s,2500s....etc result. So how to define ´╝ƒ If I inserta command ,so how to write the APDL command ?
Viewing 2 reply threads- The topic ‘How to output the result of the corresponding time during calculation ?’ is closed to new replies.
3767
1333
1173
1090
1014
