May 10, 2024 at 8:09 am
gwqsz
SubscriberHow to output the velocity, separation position, diameter and separation time of the particles stripped from the Euler wall film?
May 10, 2024 at 9:29 am
Forum ModeratorCheck the DPM Summary options and set the film wall surface. You'll need to check if the file contains the creation (flow) time or flight time.Â
May 10, 2024 at 10:59 am
gwqsz
SubscriberThank you very much for your reply. Unfortunately, I can confirm that this method is not correct. This method can only obtain the information of particles absorbed on the wall, not the information of particles stripped from the Euler wall film.
May 10, 2024 at 2:02 pm
May 11, 2024 at 11:54 am
gwqsz
SubscriberThank you very much for your reply. In fact, I have tried this method before, but I found that after removing the duplicate particle ID in the resulting file, the number of particles is not consistent with the number of s stripped from the Euler wall film, and there is always a part of particle id not in the resulting file. I can confirm that this omission is not caused by manipulation of the resulting file.
May 16, 2024 at 3:18 pm
Forum ModeratorI'll ask this side.Â
May 17, 2024 at 3:24 pm
Forum ModeratorAnd the response is either the interior method or write a UDF to track particles are they're created and write the position to a file. You've found some potential issues with the former, and re the latter, that's about all I can suggest other than read the UDF manual. Enhancement request going in as it's a useful feature.Â
- The topic ‘How to output the particle information stripped from the edge of the Euler wall’ is closed to new replies.
