LS Dyna
LS Dyna
How to output the nodal history stress
    • longt8
      I want to output the nodal stress. I have checked the instruction on LS-DYNA manual(https://ftp.lstc.com/anonymous/outgoing/support/FAQ/solid_output ) and I find I need to give NODOUT as Stress or All and I need to load elout to get the nodal stress.
      In the end, I find elout file is empty.
      My ELFORM = 1
      This is how I set the DATABASE_EXTENT_BINARY card:
    • tslavik
      With *DATABASE_ELOUT you must use, for example, *DATABASE_HISTORY_SOLID, to identify which elements should report to the ELOUT file.
    • longt8
      Hello tslvik I know *DATABASE_ELOUT and *DATABASE_HISTORY_SOLID or *DATABASE_HISTORY_SOLID_SET should be used at the same time. <- combination 1
      The combination 1 is to output the element stress rather than nodal stress, is there any way to output the nodal stress? the nodal value is my goal,
      I also know *DATABASE_NODOUT and *DATABASE_HISTORY_NODE or *DATABASE_HISTORY_NODE_SET also should be used at the same time. <- combination 2
      - combination 2 seems can output nodal stress, but option can not be found by combination 2:
      Could you give me the suggestion to output the nodal stress directly?
      Thank you!
      Best Teng
    • Kyle
      Hi Teng Have you figure out this issue since I have the same problem with it to output the engineering stress-strain and/or true stress and strain. I am not pretty sure how to get the output, very new to LSDYNA!
      Kyle Mao
  • The topic ‘How to output the nodal history stress’ is closed to new replies.
