January 9, 2025 at 6:56 am
12125084
SubscriberI found the same question on the forum(https://innovationspace.ansys.com/forum/forums/topic/how-to-output-ansys-aqwa-pressure-contour-as-csv-file/), but for some reason, the answer to that question is not displayed. Therefore, I am asking the question again.
I have a project in AQWA 2024R1, and I have produced a contour of wave elevation amplitude that looks like this. I cannot figure out if there is a way to output this contour data as a .csv file. There is no Export option in AQWA. Any help would be greatly appreciated.
January 10, 2025 at 11:13 am
Mike Pettit
Ansys EmployeeHello,
This feature has been added in Release 2024 R2. Please update your installation, if possible, and then you will be able to export wave elevations and surface pressures to CSV file.
If you are restricted to an earlier version, you can use AqwaFlow to output wave properties at specified locations. Please refer to the AqwaFlow user guide for more information: https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/aqwa_flow/aqwa_flow_intro_chap.html
Mike
January 15, 2025 at 7:09 am
12125084
SubscriberThank you very much for your reply. I will give it a try in 2024 R2.
