February 14, 2019 at 6:48 pm
cantaloupe1
SubscriberHi,
How do I open a .hfss file in ansys?
The file that I am trying to open has extension.hfss, and was created in hfss version 13. My school has ansys version 19.1 installed on its machines, it has "hfss" "hfss 3d layout design" and "hfss-IE" analysis systems
Thank you
February 14, 2019 at 7:03 pm
cantaloupe1
Subscriberwhen I click on "hfss", 4 options pop up:
- HFSS
- geometry
- setup
- solution
I then click on geometry, and the "ansys electronic desktop" window opens up, but there is no option to open .hfss file
February 14, 2019 at 9:23 pm
Sorceress Gia
Ansys EmployeeÂ
First open the 'ANSYS Electronics Desktop' program. From here, click 'File' in the menu in the upper left of the screen, then click 'Open'. In the dialog box that pops up, navigate to the directroy where you *.hfss file is stored, then select *.hfss as the filetype from the drop-down menu. You should now be able to see and open your *.hfss file.
February 15, 2019 at 6:43 am
cantaloupe1
Subscriberthank you
- The topic ‘how to open .hfss file in ansys’ is closed to new replies.
3572
1188
1076
1063
952
