February 29, 2024 at 7:51 am
abdelhakim.kheriefnacereddine
Subscriberhello,
i was worked with version of Ansys Student version r2 2022 , and my licese now has expired , then for download other trial version , i did't find the older version ( r2 2022) , i found newer version such as r1 and r2 2023 and r 2024 , i think that my old files cannot be opened with the newer versions . i there a way to solve this problem ?
February 29, 2024 at 11:55 am
Forum ModeratorHave you tried opening the older files in the current version?Â
February 29, 2024 at 1:58 pm
SubscriberI have not yet downloaded any of the recent versions, R 2024, R1 and R2 2023. I just wanted to ask and inquire before downloading any of these versions. Will it actually enable me to open files created by the Ansys R2 2022 program based on your experience
February 29, 2024 at 2:57 pm
Forum ModeratorUsually there are no problems. There can be some changes in behaviour so running models on may require checking a few settings. The only time I've seen major problems is reading files from very old (5-10 releases ago) into the new version where something significant changed in the model(s). Note, there have been licence changes so there may be some solver specific issues: you should be OK opening those cases on Teaching or Reseach keys that the University own.Â
- The topic ‘how to open file in created with old version’ is closed to new replies.
- acces to path ‘session_files’ is denied error
- unexpected license problem; exiting. hit return to exit.
- Ansys Student 2025 R1 – Ansys Discovery did not install
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Can not find Spaceclaim option in ANSYS2024R2 workbench
- Workbench application not showing up after installing Ansys Student 2024 R2
2968
970
857
750
599
