Photonics
Photonics
How to obtain the propagation loss in phase-shifted bragg grating waveguide
    • ddol410
      Good day,
      I'm trying to obtain an accurate propagation loss in the phase-shifted Bragg grating structure by using two analysis methods: EME solver and 3D FDTD, respectively. Although I know the solution using FDE solver to multiply loss by the total length, it is preferred for infinite waveguides rather than for the grating structures. There are additional losses which are the sum of radiation loss, coupling loss, scattering loss, and so on.
      It is important for me to ultimately calculate the Q factor by using the obtained losses. I would be grateful if someone could introduce the right method to calculate these losses.
      Thank you.
    • Guilin Sun
      You can use FDTD simulation to get Q and resonate frequency. Pleae refer to Quality factor calculations for a resonant cavity
      other examples  https://optics.ansys.com/hc/en-us/sections/360006919094-Resonators
      You can use both FDTD and EME to get the totla loss, with loss=1-R-T.
      However, if the loss is small, the result might be very senstive to mesh accuracy and other factors.
      Please check which method is better for you.
  • The topic ‘How to obtain the propagation loss in phase-shifted bragg grating waveguide’ is closed to new replies.
