How to obtain the normal stress?
    • M210098
      I have attempted a simulation exercise on this assembly here in one of the innovation courses.
       After running the model, I apparently did not obtain the right answer for the normal stress which was supposed to be zero. Instead, I have only gotten 0.79MPa. Could it be due to me looking at the wrong place for it? Attached below are the relevant outputs and steps I have taken.  May I enquire as to where went wrong with my simulation and provide some suggestions for the causes? May I also trouble you to provide some elaborations for the solution as I am still new to Ansys? Thank you.
    • erik.kostson
      Hi
      Which course is this?
      Pleae attach the course link so we can have a look in order to provide feedback.
      Erik
    • M210098
      This is the course link for the course and its simulation exercise.
      https://innovationspace.ansys.com/courses/courses/geometry-representation-using-ansys-mechanical/lessons/practice-quiz-and-simulation-exercise-2/quizzes/simulation-exercise-geometry-representation/
    • erik.kostson
      So for the question in that tutorial –in the normal stress probe you shown, the Z orientation is set, but in the Coordinate System, choose the Solution Coordinate System (not global) since it is asking for local z-direction (local z-dir. is thickness direction in the shell, hence why it is zero).
    • M210098
      Thank you, it worked out well.
    • erik.kostson
      That is great - all the best
      Erik
Viewing 5 reply threads
  • The topic ‘How to obtain the normal stress?’ is closed to new replies.
