September 4, 2023 at 9:11 am
Haiquan
SubscriberDear ANSYS support team
I am going to perform the viscoelasticity harmonic for a ruber like material at room temperature. Material supplier told me they only can do the compression DMA test for such frequency dependent properties, I am worried about the simulation accuracy with properties obtained with a comprssion test. Is there a requirement for such material properties testing? Is there a test standard? Thank you!
September 5, 2023 at 8:09 pm
wrbulat
Ansys EmployeePlease have a look at this solution:
/knowledge/forums/topic/how-can-one-convert-frequency-and-temperature-dependent-viscoelastic-data-to-a-prony-series-for-use-in-ansys-mechanical/
- The topic ‘How to obtain the frequency dependent properties in a ruber like material’ is closed to new replies.
