November 22, 2020 at 2:25 am
MarkFei
SubscriberHow can I obtain a half model from full model in spaceclaim, just like the symmetry feature in DesignModeler?n -
November 22, 2020 at 5:29 pm
peteroznewman
SubscriberI'm using SpaceClaim in ANSYS 2020 R1 and I haven't found the kind of automation that DesignModeler provides for including symmetry.nI just make a plane, and use the Split Body tool to cut a body in half. If you have several bodies, I select them one after another. I haven't found the split body tool works on multiple bodies at once.nAfter the geometry has been imported to Mechanical, there is a Symmetry Region, but I will often create a Displacement BC to create the symmetry boundary condition.n -
November 23, 2020 at 1:11 am
MarkFei
SubscriberThank you sir, I have figured it outn -
July 17, 2023 at 2:02 pm
mechE
SubscriberCan you please explain how you fiigured it out?
- The topic ‘how to obtain a half model from full model in spaceclaim’ is closed to new replies.
