February 28, 2017 at 9:42 am
Nikita
Ansys EmployeeConjugate heat transfer (CHT) simulation with respect to mesh morphing: The solid is moving with a solid body motion, the fluid domain is partly following by means of mesh morphing e.g. piston of an internal combustion engine. Monitoring ‘areaInt(Wall Heat Flux )@Domain Interface 1 Side 1’ at the fluid side of the moving CHT interface provides wrong values
March 21, 2017 at 12:05 pm
Vishal Ganore
Ansys EmployeeOn a moving interface the wall heat flux values do include the complete enthalpy flux across the interface. They also contain the pressure work (Pressure*Area*Velocity) at the moving fluid/solid interface. The correct wall heat flux is available at the solid side of the interface. Monitoring ‘areaInt(Wall Heat Flux )@Domain Interface 1 Side 2’ contains the right value.
- The topic ‘How to monitor the wall heat flux at a moving CHT interface?’ is closed to new replies.
5694
1891
1419
