August 5, 2024 at 12:15 pm
Md_Salem
SubscriberHello everyone,
I built some surface plate using designmodeler, I need to change the material of smoe spot on this plate.
how can I assign some spot on this plate to change its material ?
I thought to remove a part from the plate and add equivellent one then glue it. Hence, I accan assign the other material to that part, am I right ?
Regards
August 6, 2024 at 1:34 pm
Aniket Chavan
Forum Moderatorit depends on what operation will needed but you will certainly need a separate body to assign separate material.
-Aniket
August 6, 2024 at 1:36 pm
Ashish Khemka
Forum ModeratorHi,
You can cut and retain the cut portion of the material to have multibody part, share the topology and assign a different material to the region of interest in Mechanical.
Ashish Khemka
August 8, 2024 at 8:27 am
Md_Salem
SubscriberHi Anshish,
This exactly what I want to do. My question is how to performe the cut opertation from the surface body after it is already generated in Deignmodeler ?Â
Regards
5824
