How to model transient thermoelectric coolers simulation in workbench
    • aakashmani.rs.mec23
      Dear friend
      I did steady-state analysis of thermoelectric coolers and now I need to do a transient analysis of thermoelectric coolers, so please tell me in which Anslysis system of the workbench I can model the transient thermoelectric analysis. For steady-state anlysis I have used Thermal- Electric Anslysis system of workbench in which Steady-State Thermal-Electric Conduction is used.
      So please tell me the way to do transient analysis of thermoelectric cooler.
    • ErKo
      For transient thermal electric we can use coupled field transient system.
      https://innovationspace.ansys.com/forum/forums/topic/electrothermal-simulation-of-a-fuse-temperature-problem/
      The conduction feature is added in 2023R1 but I have 2022R2 is there any way to do it in 2022R2
      The conduction feature is added in 2023R1 but I have 2022R2 is there any way to do it in 2022R2.
      Are you sure that the coupled field transient system will capture the thermoelectric effect ?
    • ErKo
      If you are using an old version just use thermal-electric system you used, and just add some apdl commands under the solution to make it transient instead of steady state:
      see here:
      https://innovationspace.ansys.com/forum/forums/topic/how-can-i-perform-a-transient-thermal-electric-simulation-in-ansys/
Viewing 4 reply threads
