TAGGED: apdl-coding, ekill-elements, mechanical-apdl, transient-thermal, welding
January 21, 2021 at 4:39 pm
k_ujjwal
SubscriberFebruary 3, 2021 at 7:32 pmdlooman
Ansys EmployeeIt looks like there should be an esel,all command after line 23.nFebruary 4, 2021 at 5:29 amk_ujjwal
SubscriberI don't think so. It's going to select all the dead elements at once and apply load on them, which I don't want.nFebruary 4, 2021 at 7:58 pmwrbulat
Ansys EmployeeI'm quite certain that all elements (active or not) should be selected prior to every SOLVE you do, so Dave's suggestion is probably a good one. I don't think you have to remove HFLUX loads from faces of deactivated elements - it looks like the code does that automatically and internally for you:nn
n
February 9, 2021 at 2:13 pmViewing 4 reply threads- The topic ‘How to model material deposition in ANSYS APDL?’ is closed to new replies.
5169
1836
1387
1249
