September 14, 2021 at 7:04 pm
poojasudha
SubscriberHey,
I have modeled two similar antennas in front of each other, so that the radiation field of first antenna can work as source for the second antenna.
Is this a correct way to model a receiving antenna or are there any other methods to model the same.
September 15, 2021 at 2:38 amAndyJP
Subscriberyou are modelling a path. the antenna without a biased ferrite is reciprocal, so there is no difference between receiving and transmitting. you just have to be careful with power parameters definition, when calculating what you need.
September 15, 2021 at 5:39 ampoojasudha
SubscriberHey
could you please elaborate?
September 15, 2021 at 5:40 ampoojasudha
SubscriberFor port 1 the power used is 1 W & for port2 the power used is 0 W.
September 16, 2021 at 11:40 amPraneeth
May I know what characteristics of the antenna you are trying to analyze in receiving mode?
In general the antennas are reciprocal devices. So it is sufficient to analyze only one antenna model in the simulation tool.
All the very best.
Viewing 4 reply threads- The topic ‘how to model a receiving antenna in HFSS?’ is closed to new replies.
Innovation SpaceTrending discussions- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
Top Contributors-
4167
1487
1338
1171
