July 19, 2021 at 10:19 am
moustafa
SubscriberHello,
I have made a density-based lattice topology optimization. To do a Static Structural analysis with the optimized part, meshing needs to be done. However it is not feasible; whenever I want to mesh, it ends with an error.
I would appreciate suggestions how to solve this problem. There is a picture of the geometry.
August 10, 2021 at 2:03 pmAniket Chavan
Forum ModeratorThis can be a bit tricky without increasing the mesh too much, what error do you get while meshing? Have you tried patch independent mesh methods virtual topology etc?
Would it be useful to calculate equivalent material properties using a material designer instead?
-Aniket
August 10, 2021 at 9:00 pmmoustafa
SubscriberThank you for the answer. Yes, I tried these methods, but they did not work so far. May you explain to me how to calculate the equivalent material properties using a material designer?
Kind regards
Heisam
July 6, 2023 at 11:55 amAshish Khemka
Forum ModeratorHi Heisam,
Please see if the following link helps.
Introduction to ANSYS Material Designer - YouTube
Ashish Khemka
Viewing 3 reply threads- The topic ‘How to mesh a complex lattice structure’ is closed to new replies.
5739
