December 3, 2019 at 6:10 am
December 3, 2019 at 12:16 pm
peteroznewman
SubscriberWhy do you want to merge the lines?
If you do something like pick both lines and Pull a surface from them, you will get a single surface body with two faces and the lines will disappear.
If you want two beams to be connected, first you convert the lines into beams on the Prepare tab and then use the Share button on the Workbench tab to weld them together at a common node.
December 3, 2019 at 12:32 pm
FrankD
Ansys EmployeeFurther, Fit Curve makes a spline (which by definition cannot have a sharp internal discontinuity)
If you need a surface with no visible tangency, upon extrusion, then you have to make sure to sketch a tangent arc (or spline) between the straight lines, first.
F
- The topic ‘How to merge line in rectangular ?’ is closed to new replies.
Ansys Innovation Space
- FSAE CFD – Lesson 1 Preparation question (Using Discovery)
- Add-in Error Excel
- Missing SubDivWrapper.dll
1414
1256
1118
1015
