October 4, 2023 at 10:39 am
luna6362
SubscriberHi,I am simulating a compressor.
And I need to know the velocity in the rotating tube inside my compressor.
I used Probe and enter the coordinate to see the answer.
But the coordinate can't move arround with the rotating tube.
The other problem is I don't know the coordinate after my model rotates.
So I can't use Probe to see what I want to know.
Is there any better method to see the velocity inside the rotating tube?
Thank everyone who want to help me!
October 4, 2023 at 1:36 pm
Federico
Ansys EmployeeHello Luna?
Can you show a screenshot of what your model looks like? What is this tube exactly, and is it rotating about its axis?
October 5, 2023 at 4:52 am
luna6362
SubscriberÂ
Hello Federico Alzamora Previtali
Thank you for your reply!
Sorry that I forgot to add screenshots on my post.
Here is my model’s screenshot.
I circled the rotor in my compressor(the yellow one model).
I had hiden some components to that it be clearly.
And the tube looks like this by the side.
I need to measure velocity inside the yellow tube.
And my rotor rotates along axis successfully.
This is the screenshot at 1s.
This is the screenshot at 2s.
October 5, 2023 at 8:43 am
Forum ModeratorTo clarify, you want to add a monitor that's somewhere in the fluid zone and moves with the rotor?Â
October 5, 2023 at 8:50 am
luna6362
SubscriberHello Rob.
Yes,that is exactly what i want to do.
But I am not sure which function is the best choice.
Thank you so much.
October 5, 2023 at 9:05 am
Forum ModeratorMoving monitor points isn't practical. However, using a register to separate a single cell to monitor is.Â
October 5, 2023 at 9:15 am
luna6362
SubscriberThank you so much,Rob. I will try it.?
October 6, 2023 at 5:51 am
luna6362
SubscriberHello Rob. Sorry for disturbing you again.
I am wondering is this tutorial show what you tell me before?
https://www.youtube.com/watch?v=JAnCibZmGJg
And I want to ask you that can i use register to see the velocity after the calculate compliete?
Really appreciate again!
October 6, 2023 at 3:41 pm
Forum ModeratorMostly, except you are going to split the mesh using the register. That will give you a small region to monitor whatever you want on.Â
- The topic ‘How to measure the velocity inside the rotating tube?’ is closed to new replies.
