October 29, 2019 at 3:49 pm
Anand0312
SubscriberHow to measure the angle of rotation of turbine blades for a particular position or for a particular autosave file from the output in ANSYS Fluent?
October 29, 2019 at 4:51 pm
Amine Ben Hadj Ali
Ansys EmployeeYou have time duration and angular speed. -
October 29, 2019 at 5:10 pm
October 30, 2019 at 7:15 am
Amine Ben Hadj Ali
Ansys EmployeeYou define a small UDF or expression where you multiply the angular speed with the time step size.Â
November 2, 2019 at 9:25 am
Anand0312
SubscriberHow to define a UDF in Ansys Fluent? If you have any tutorial on that then please forward the link.
July 4, 2023 at 5:48 am
dhanjita medhi
SubscriberHello, for blade oscillation (or amplitude) of 10 degree, I am using a expression of 0.174*43.689[rad/s]*cos(43.689[rad/s]*t) in cell zone conditions under rotatinoal velocity (in which 43.689 rad/s is the rotational speed of the larger rotating domain and expression is for blade domains). In my problem, the blade pitch angle variation is sinusoidal and that's why I am using a expression for rotational speed by derivating the pitch angle expression as dtheta/dt is angular speed. Now I want to check whether blades are pitching with amplitude of 10 degree or not? Can you please help me to measure the angle of rotation of the blades? or how can we check whether my expression is working or not?
- The topic ‘How to measure the angle of rotation of turbine blades in Ansys Fluent?’ is closed to new replies.
3150
1013
956
858
797
