Electronics
Electronics
How to measure magnetic field strength with complex port impedance?
    • nadeemrather
      If I use a probe to detect the etic field from a coil antenna then how can do the same in HFSS given the fact that the coil antenna tested has a matching circuit and in simulations, don't have any, Rather I have matched the port impedance to the antenna. which is a complex impedance of antenna resistance plus inductive reactance of the coil... I am not able to get the results on my simulation when trying to match it with measured. I used a vacuum cylinder of the area as the probe flux area.
      p.s I just want to check the magnetic field received by a specific flux area near the antenna, which should be same as measured
Viewing 0 reply threads
  • The topic ‘How to measure magnetic field strength with complex port impedance?’ is closed to new replies.
