TAGGED: acp, acp-compositematerials, bonded, bonded-contacts, mechanical, meshing
April 3, 2024 at 5:03 pm
Daniel Cole
SubscriberI have used ACP to define a composite structure where 2 faces are layed up inwards and meet along one region, however when a load is applied in static structural the two layups act independently. As depicted in the attached image, the lower layup is unaffected when a load is applied to the top layup. Is there a way for Ansys to recognise the area in which these two layups meet, to form a single solid body?
April 4, 2024 at 8:49 am
Akshay Maniyar
Ansys EmployeeHi Daniel,
Have you defined any contact between the parts?
Thanks,
Akshay Maniyar
- The topic ‘How to make two meeshed regions behave as a solid body?’ is closed to new replies.
