May 26, 2025 at 5:22 pm
enrmarvil
SubscriberHi everyone, I need a little help, I´m making a centrifugal compressor in BladeGen, but all the geometry is made in this module from zero. then when i want to mesh the machine, it´s show me this error
I think this problem take place bcs of use BladeGen to made the full geometry instead of Vista CCD + BladeGen. The thing is that I don´t wanna use Vista CCD, and in replace I´m using a 1D code to generate a premodel of the compressor, and then I put the data of the code in BladeGen, and modify the geometry manually.
If anyone can help me to solve this problem, I will be very grateful.
May 28, 2025 at 12:59 pm
CFD_Friend
Ansys EmployeeHi,
This is merely an error. You can ignore this, and it won't affect your simulation or mesh in any way. But if, like an inlet domain, you also want a separate outlet domain, you can specify "Split mesh Regions at Trailing edge" option in the Topology set settings. This will split the otherwise continuous passage at the trailing edge. This results in a separate outlet domain similar to the inlet domain.
3150
1008
935
858
792
