Electronics
Electronics
How to make external circuit
    • hyungjun Kim
      Hello, I am a student studying electromagnetism and learning about AFPM.
      Using RMxprt, we would like to conduct easy modeling to conduct learning and simulation, and create a homemade generator to conduct learning.
      Before that, we want to use Maxwell 2d to model and interpret directly in the same way as RMxprt, but why we need an external circuit and whether there is a specific circuit for the generator model.. And I wonder if I have to conduct the test by configuring the same circuit when I test the generator by manufacturing it myself.
      I want to configure a multi-layered afpm additionally, do I need to change the circuit?
      thank you
    • Timos
      Hello, you should not change anything in this circuit. It is automatically generated based on the RMxprt setup (motor or generator) in order to create the expected excitations.
      • hyungjun Kim
        Thank you Timos
        I want to make Multi Layer AFPM using only Maxwell 2D or 3D without using Rmxprt.
        By any chance... can we model Multi Layer AFPM with Rmxprt?
        Basically, I understand that we only offer One Statr One Rotor.
        If I change the maxwell design, will an automatic circuit be created based on Rmxprt?
        Please keep in mind that it may be a bit awkward to write down with the help of a translator because I am not good at English.
  • The topic ‘How to make external circuit’ is closed to new replies.
