August 1, 2024 at 11:33 pm
Alex Chiella
SubscriberHi! I have got an elbow pipe with a stream at -100°C, surrounding atmosphere is air at 20°C.
I'd like to know how to make the wall adiabatic.
If I set the heat transfer boundary condition to 0 I get this:The're a gradient on the outside.
There's no material flow through the wall:
Now, the adiabatic hypothesis is quite strong and I might even take this "smoothing" as it is without posing question, but I have two issues:- Here, it looks like the pipe is behaving more like an ideal heat source at T=Twall_cell. Which might be useful, but it really is not anything I have ever been taught as adiabatic
- The main one: it gives me some issues with residuals and convergence
Where am I messing up? At some point I'll hopefully have the time to properly initialize the wall heat transfer, but till then I'd much rather shut off any heat flow there.
August 2, 2024 at 7:42 am
SRP
Ansys EmployeeHi,
You can define an adiabatic wall by setting a zero heat flux condition. This is the default condition for all walls.
Thank you.
August 2, 2024 at 8:40 am
Alex Chiella
SubscriberÂ
Hi SRP, thanks for reaching out!!
The problem is that it looks like it’s not working. This is set way I initialized all my walls:
Yet, I do see an air Temperature gradient right at the wall, with no other temperature differences or heat sources available. What did I get wrong?
P.S. I just noticed that multi-editing didn't quite work and that some walls were automatically initialised as coupled. I'm checking that out right now
August 8, 2024 at 10:36 am
Forum ModeratorA coupled wall should have heat passing through it - it's the boundary between the fluid and whatever is containing it. So, wall & wall:shadow which represent the "wet" and "dry" sides, but not necessarily respectively.Â
5824
