October 23, 2021 at 8:01 am
mrigola
SubscriberI am trying one problem of Seismic response analysis to a Block type Deep soil -pile model .This DSPM is nothing but Engineered soil-cement mix which will give me at least 10mpa compressive strength with a dimension of the block 24mx24mx25m deep in a Elastic soil.The size of the Soil Boundary 75mx75mx50m. Now If I model these components using Ansys2020R1 .Here the Boundary soil may be Moderate strength Clayee soil having Subgrade stiffness=5E+07N/m3
1.How do I put the Absorbing Boundary condition using Ansys2020 R1
M N RAY
October 27, 2021 at 5:49 pmdlooman
Ansys EmployeeThe INFIN257 element (in APDL) can be used outside the elastic soil to represent an infinite structural domain.
October 28, 2021 at 1:01 ammrigola
SubscriberThank you dlooman for your suggestion. I will revert back shortly.But will this element will act like an interface element which can be glued to the outer face of the soil contoniam ?
October 28, 2021 at 1:04 ammrigola
SubscriberSorry I meant Soil Continuum.
October 29, 2021 at 6:25 ammrigola
SubscriberDear Dlooman I have gone through the Ansys Element INFIN257 from Ansys Mechanical element ref doc and noted that I have to develop these elements as an additional layer over my soil elements(Solid 186 which is already modelled ).But I am not getting any reference of APDL command lines to do this job as the command lines to develop INFIN257 is required to be known for inserting the same.I will be grateful if you can throw some light.
Viewing 4 reply threads- The topic ‘How to make Absorbing Boundary condition in a 3D Soil -Structure model using Ansys202R1’ is closed to new replies.
5819
