August 26, 2024 at 9:35 am
35020306
SubscriberDear all,
I am currently working on a two way FSI analysis model that replicates a bridge deck section model being tested inside a wind tunnel. For that purpose I have created a fluid domain with zone division as shown in the picture below. I am planning to apply System Coupling to the Deck Zone in order to transfer forces as input to the mechanical model in the Transient Structural analysis block. However, I also want to preserve the mesh around the faces of the Deck Zone by having the Rigid Body Zone moves together with the Deck Zone as a rigid body. I have tried assigning "rigid body" status to the Rigid Body Zone in the Dynamic Meshing, however the option box says that I need to specify Motion UDF/Profile. Is it possible to configure the surrounding zone so that it moves together with the deck as a rigid body?
August 26, 2024 at 2:26 pm
Federico
Ansys EmployeeHello Audy,
The short answer is no. When doing 2-way FSI, fluent will pass forces to the structural solver, which will pass back displacements to Fluent. This is done on each cell face in the system coupling interface. Hence, I am not sure which displacement exactly you would want to apply on the Rigid Body zone.
Is there a reason why you want to preserve the zone around the Deck Zone as a rigid body?
As you have stated, the Rigid Body Zone is meant to assign a prescribed motion to an entire cell zone.
5674
1890
1419
1304
