How to make a time vs volume fraction graph in Ansys Fluent 2020 R1 (Student Product)?
    • Stefanotepo0
      Hi all, I have modeled lot of multiphase models for my dissertation, consisting water (in red) and methane (in green). I want to plot graphs of time vs volume fraction of methane and do not know exactly how.
      Can someone explains the steps on how to plot a time vs volume fraction graph in Ansys Fluent? To show more details, I am using Ansys Fluent 2020 R1 which is free for student.
      Please, someone help. I appreciate deeply to any kind of help
      Sincerely,
      Stefano
      Look at Report Definitions. You'll also need a point or surface depending on what you want to monitor to provide a location for the monitor.
    • Stefanotepo0
      Dear rwoolhou,
      Thank you so much, you helped me a lot. but the plot has been saved as an .out file. Do you know how to read that file and import it to the excel?
      Sincerely
      Stefano
    • Stefanotepo0
      That's alright, it is solved now. Thank you so much rwoolhou.
      To add for others looking at the thread, the .out file is text based and usually reads into Excel as space delimited for the purpose of plotting the output.
    • iferemike1
      good day im doing something similar, i am modelling a multiphase air water flow in an horizontal pipe, im to plot liquidholdup vs time. can you give me any heads up on setting the fluent solver, im using vof k-e, and my geometry has two inlets. i also want to obtain pressure gradient after simulatingn
    • iferemike1
      a little help with boundary conditionsn
      This will help with the free surface position, /forum/discussion/4891/measuring-water-depth-of-a-channel-flow-in-ansys-fluent As for the boundary conditions please post a new thread. n
    • PENIEL MALWENA
      i would like to know also how to make
      The cavitation performance curve of tubular-pump model vs NPSH
Viewing 8 reply threads
  • The topic ‘How to make a time vs volume fraction graph in Ansys Fluent 2020 R1 (Student Product)?’ is closed to new replies.
