3D Design
3D Design
How to loop blend script through several curves.
    • Jthibault
      I have imported a point curve text file as a series of 141 evenly spaced curves and wish to use the blend tool to make them into a surface. I want to create a general script to apply the blend tool to each pair of curves in sequence.
      Essentially what I want to do it perform this code block:
      # Create Blend
      selection = Selection.Create(Curve1, Curve2)
      options = LoftOptions()
      options.GeometryCommandOptions = GeometryCommandOptions()
      result = Loft.Create(selection, None, options, Info1)
      # EndBlock
      and subsequently iterate Curve1 and Curve2 through all pairs of sequential curves in CurveFolder1
    • Aniket Chavan
      would it work if you pythonically read the file and bring only two curves at a point blend them, and later delete them, and repeat?
      -Aniket
  • The topic ‘How to loop blend script through several curves.’ is closed to new replies.
