June 4, 2021 at 7:42 am
Jagmohan
SubscriberCan anybody tell how to link the ice-pack In ACT Extension with project design?
June 4, 2021 at 5:39 pmVivekKamble
Ansys EmployeeHello
If you are looking for EM to Icepak linking please refer to this video https://youtu.be/Ook62EZHPVA.
Regards Vivek
June 5, 2021 at 2:22 amJagmohan
SubscriberHello Thanks for your response.
I have already watch the video. The Icepack is not shown in my ACT Extension. I am using HFSS 2019 R3 v.
Thank you,
Jagmohan
Viewing 2 reply threads- The topic ‘How to Link the Ice-pack design in ACT extension?’ is closed to new replies.
Ansys Innovation SpaceTrending discussions- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
Top Contributors-
3862
1414
1220
1118
1015
