February 24, 2023 at 10:03 pm
Souani.Safer
SubscriberHi,
I am modelling heating effect on illuminated metallic nanotip (coupling DGTD+HEAT), the model works well, the only problem that I have is how to introduce the interfacial thermal resistance between a metal and a dielectric in the model.
Do I have to add a thermal resistive layer of 0.5 nm or 1 nm with a low thermal conductivity or another way but I do not see any possibility of adding an interfacial thermal resistance.Do you have any idea for solving this issue?
Thanks in advance for your time and help.
Best regards,
February 24, 2023 at 10:16 pm
Guilin Sun
Ansys EmployeeThe solver automatically counts the thermal resistance at the material interface, since their heating property is not the same. Please refer the solver physics  https://optics.ansys.com/hc/en-us/articles/360034917713-HEAT
February 25, 2023 at 8:48 am
Souani.Safer
SubscriberThanks a lot for your reply and help.
Best regards.
- The topic ‘How to introduce an interfacial thermal resistance between two materials.’ is closed to new replies.
