Photonics
Photonics
How to interpret the electric field data
    • Z.Shahrabifarahani
      Hello everyone,
      I ran my result and got my results for the electric field. I have used both DFTmonitor and Monitor expansion. I have such a formula to calculate the potential only with the fundamental mode:
      U= Ex * conj(Ex) + Ey * conj(Ey) + Ez * conj(Ez)
      Using the monitor expansion, I have "a" and "b" coefficints, corresponding to transmission coefficints of each mode. And "output power" from DFTmonitor, let's name it P_simulation.
      Also, I want to calculate the potential with power P_desired=30mw. I wonder if this correction makes sense:
      U= abs(a_fund-mode + b_fund-mode) * P_desired / P_simulation   *    [Ex * conj(Ex) + Ey * conj(Ey) + Ez * conj(Ez) ]
    • Guilin Sun
      is the Poynting vector along z axis;
      seems reasonable. however
      is not reasonable, since a and b are  the transmission/reflection complex coefficients and they usually do not work to be summed up and apply to power quantities.
      Please check your original idea of “potential”: what exactly does it mean in math expression in physics?
      Hi, I need to apologize and correct my definitation for potential:
      alpha is the polarizability of atomic system. I got the components of electric field for my desired mode from the mode expansion monitor. Just to correct the portion of power carried by this mode, I used a and b coefficients.
    • Guilin Sun
      a and b coefficients are not the full description of the power portion. please refer to this article:
      https://optics.ansys.com/hc/en-us/articles/360034902433-Using-and-understanding-Mode-Expansion-Monitors
      you have all the results you need from the simulaiton. Hopefully you can get your desired result.
  • The topic ‘How to interpret the electric field data’ is closed to new replies.
