TAGGED: lumapi, Lumerical-CHARGE, material-properties
October 11, 2023 at 3:10 pm
Duarte Silva
SubscriberI want to be able to create GaInAsP alloys in lumerical CHARGE programmatically, particularly through the Python API. How can it be done?
October 13, 2023 at 5:05 pm
Guilin Sun
Ansys EmployeeYou will need to know how to add such alloy using Lumerical script, then use Python to set it.
https://optics.ansys.com/hc/en-us/articles/360034398514-Tips-for-creating-a-new-alloy-material
https://optics.ansys.com/hc/en-us/articles/360034404974-addmodelmaterial-Script-commandÂ
https://optics.ansys.com/hc/en-us/articles/360034924933-addmaterialproperties
please post any further questions in the Photonics forum: /forum/forums/forum/discuss-simulation/photonics/
October 17, 2023 at 1:08 pm
Duarte Silva
SubscriberIndeed, but the problem is that I have not found a way top insert it even within lumerical scripting. Is it possible?
October 17, 2023 at 3:30 pm
Guilin Sun
Ansys EmployeeIt seems there is no direct script to insert alloy. But you can set some alloy materials that you want to use, and use
to the "materials" folder, and in the "model" you can assign material to a geometry. Using Lumapi to assign the "model".
However the api is not fully developed so please try and see if it works.Â
October 17, 2023 at 4:06 pm
Duarte Silva
SubscriberI understand. What I was trying to avoid was to have to search all the references to the 4 materials since you already have all the work done. What I was doing so far was to add the InP material and then alter the bandgap and mobilities, but there are many other quantities. It would be very useful to be able to use your database that fluently. This is useful when one wants to scan various concentrations of the alloys.
October 17, 2023 at 4:41 pm
Guilin Sun
Ansys EmployeeYou can use "set" to modify most material properties: https://optics.ansys.com/hc/en-us/articles/360034919213-Creating-and-modifying-electrical-materials-from-a-scriptÂ
- The topic ‘How to insert a quaternary semiconductor alloy (GaInAsP) through lumapi?’ is closed to new replies.
